Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 06-10-2013, 08:13 AM
305M3's Avatar
Trader Rating: 43 (100%+)
Default Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
The next generation of the Lazer ZX series is here!
In the world of EP 4WD racing, the Lazer ZX series has been competing and winning at the highest levels of RC racing for years. And now the newest evolution of the Lazer ZX series is here, with the all new Lazer ZX-6! Starting with an all new slim design 7075 T6 aluminum hard coated chassis with adjustable battery and motor configurations that allow the use of a shorty pack on either the left or the right side of the chassis, or the tried and true saddle pack configuration. The ball diffs are tungsten carbide equipped and include genuine X-Gear Diff lube and High Graphite grease. A new advanced steering geometry have greatly improved steering response and smoothness. The one piece shock tower/camber link mounts and composite chassis brace design add durability and ease of maintenance to this new 4WD machine. All four suspension mounts are now machined aluminum and track/toe width adjustable by the use of composite inserts for maximum tuning ability. The new Lazer ZX-6 has been designed to take your racing to the next level and beyond.
Slim 7075 T6 milled hard coated aluminum chassis with composite side guards.
New more advanced steering geometry with aluminum rack.
One piece bulkhead cap shock tower/camber link mount.
New sliding motor mount design.
Tungsten ball equipped differentials.
Adjustable motor/battery layout. Compatible with shorty or saddle packs.
Velvet coated big bore aluminum shocks with one piece aluminum caps.
Genuine X-Gear springs, ball diff grease and hi-graphite grease.
Heavy duty ring gears for a bulletproof drive train.
New cab forward body and high flow wing.
Technical Data
Length
385mm
Width
248mm
Height
145mm
Wheelbase
278mm
Tread (F/R)
210mm / 200mm
Tire(F/R)
sold separately
Gear Ratio
2.6:1 (2nd)
Weight
1,650g (without electronics)
Layouts
http://www.petitrc.com/setup/kyosho/...ctronicsSetup/
Manual
http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
Parts List
http://www.kyosho.com/jpn/support/in...R_ZX6_SPOP.pdf
Build
http://www.petitrc.com/setup/kyosho/...yEvdoka_Build/
Setup Sheets
Blank Sheet
Akimoto Kohta Champ Stadium
2014 Tebo Hot Rod Shootout
A Boatload of Sheets from Petite RC
305M3 is offline
Old 06-10-2013, 09:32 AM
offroad dude's Avatar
Trader Rating: 31 (100%+)
D@mn, let me start saving my money now. This bad boy will be at least $750 bucks..
offroad dude is offline
Old 06-10-2013, 09:41 AM
Suspended
Trader Rating: 23 (100%+)
I hope not since I will be "needing" a RT6 also
Team G Racing is offline
Old 06-10-2013, 10:40 AM
silveraider14's Avatar
Ofcourse!! To bad i just bought a zx5 fs2 sp
silveraider14 is offline
Old 06-10-2013, 10:42 AM
Suspended
Well, I did warn people on the zx5 thread and another thread they will be coming out with a new 4wd buggy
Old 06-10-2013, 10:50 AM
305M3's Avatar
Tell me about it. I started cleaning the XB4 in preps for sale...
305M3 is offline
Old 06-10-2013, 11:25 AM
Hopefully my zx5 will still be competitive! I don't see why it wouldn't be.
Old 06-10-2013, 11:35 AM
It should be. I've seen plenty of racers be competitive with older chassis.
I'm excited to see what they have in store!
JiuHaWong is offline
Old 06-10-2013, 12:19 PM
Yeah I was running a tamiya Durga dbo1 and got second first time driving it. Cause my laser broke a steering bell crank.
Old 06-10-2013, 01:37 PM
H0LESH0T's Avatar
More & more companies are running aluminium chassis. He managed 3rd place with it. Be nice to see some off body shots.
H0LESH0T is offline
Old 06-10-2013, 01:41 PM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Looks like the standard layout most buggies are using right now? Always liked the K cars for off road 1/10 but I'm going to stick with my Schumacher. Its been running great.
Dan is offline
Old 06-10-2013, 02:44 PM
FINALLY some carbon fiber and aluminum chassis for a $500 10th scale!
george919 is offline
Old 06-10-2013, 06:31 PM
Dan
Dan's Avatar
You mean $600+.
Dan is offline
Old 06-10-2013, 06:38 PM
Originally Posted by Dan
You mean $600+.
The current one is $499 so ya the new one is probably on the other side of 500
Old 06-10-2013, 08:44 PM
Hoese37's Avatar
Expect all the new Kyosho stuff to be expensive. Probaly $400+ for the RT6, and $550+ for the ZX6. Remember when the RB6 came out, it was $450.
Hoese37 is offline
